The to do list
xcalibur223
NAC VP
Pickup new tow rig!!!
Buy/borrow/rent/steal a trailer
Oil change
redo alignment
install new leaf springs
install hood vents
install hood pins
install speed bleeders on all 4 calipers and bleed brakes
install new injectors
install throttle body
Hardest part is going to be a trailer
Rob Mayercik
NAXJA Member #920
Replace seat bases (action: take pictures of driver's side one to document the failure from RocktoberFest)
Rebuild/reinstall CB mic extension cable/fix CB issues
Get pinion seal on front axle replaced
Replace tcase rear output seal
fluid changes (oil/trans/diffs/tcase)
STROKER
<-- A Tribute
Rear driveshaft
Shifters...Done
Put interior back in and install new seats
Radiator
Reinstall front bumper
Relocate battery
Wiring
S belt
Reconnect steering lines...DONE
Gas tank skid...Done
Reinstall tcase skid
Fuel pump...Done
Rear brakes and bleed...DONE
Reinstall front ds
Exhaust
new ac lines and charge the system
Reinstall hood and front clip
oh and inspection by April
I’m sure there is more that I’m forgetting...why am I building a new rig???
STROKER
Victor S.
My list is kinda short but time consuming
Figure out rough running/misfiring
Bump Stops (front and rear)
SYE and rear driveshaft
Nut and Bolt the Jeep.
Victor S.
My son just added:
Front and rear diff covers
Upgrade the tie rod
Upgrade the track bar
Lucky me!:bawl:
