Torque converter question...lock-up
ParadiseXJ
How can I tell if my torque converter is locking up...or not. I think I have a wiring problem after my AW4 swap. Was working fine...now it feels like I'm hauling an anvil behind me.
I've read the Everything You Wanted to Know thread so I don't need a link to that.
Thanks.
cruiser54
No tach, I presume. Did you install the TCC switch when you did the swap? It cuts the converter off when the brake pedal is depressed.
Can't post a photo. PM me for one if you like.
ParadiseXJ
TCC switch I assume is on the brake pedal. I used the Renix brake pedal switch, so no. I do have a tach.
PM coming.
Johnnie Walker
Piece of Fish!
You can always install a TC lock-up switch. Not only allows you to lock it up whenever you want. But would confirm if the rpm drop is occuring normally. The brake switch is one of the common causes of failing TC lock up.
043500
You should be able to fell it shift into each gear and then once into 4th/OD you should have 1 more RPM drop for the TC lock. When are you getting the 'anvil' feeling? It may be upshifting too early or locking up the TC too early which may indicate a solenoid issue and certainly make it feel as though you are heavy.
