dirt machine
Everything works fine unless it is a cold start, like after sitting overnight. Try to start and idle is too low so it dies.
Took apart throttle body and cleaned out everything, including IAC.
Still, problem persists. Furthermore, once I get it running fine, or just put it into drive and start driving a bit, problem is solved.
I can start it and turn it off all day long with absolutely no problems whatsoever. This is only on a cold start.
Any ideas would be helpful.
Thanks.
Thanks.
