Hey, I never mentioned any names and, it's the least fun I've ever had! It'll become the funnest day ever, once you come pick it up.Awe the low blows keep comin....
Did you have to moce the mj rears perches for your xj? Bout to do the same.Yanking the axles out of a MJ, swapping them with the stockers in the XJ. and then working past midnight to put the XJ's axles in the MJ just so it could roll onto a trailer for the guy who was going to buy it. That was no fun.
Yea, they measure an inch wider on each side. Sucks cuz mine has ube's, and it gonna be a pita to salvage them and move them a friggin inch!The XJ springs are wider than the mj. The Ford 8.8 that went in the jeep had perches that were about a half inch narrower on each side. They went into the XJ with just a little bit of work. They work pretty good as is. I really need to widen the perches and I will eventually but it's not keeping it off the road. They XJ springs went under the MJ pretty easy but if you look it from the rear the springs are pushed pretty wide. I didn't really care since the thing only had to roll onto a trailer.
