Whats better
azxj95
So i have a crawler i want to build another one to go fast whats better 2 wheel drive or 4 wheel drive 4 door or 2 door
tbburg
All-around, 4WD is more versatile, but racers usually go 2WD to save weight unless they suspect the course will need 4WD(Jeepspeeds are built convertible)
2-dr/4-dr,... The eternal argument. The stock 4-dr chassis is a little stiffer, and for an all-around rig, the back doors make it easier to get into the back. The 2-drs have better sheet metal arrangement for cutting out wheel openings.
They build and race both.
Personal opinion: With a fire suite, helmet, gloves etc. and crawling around a cage, the front doors are a little tight when you go to get in/out in a hurry.
two_shoes
Yes, they are better... :wierd:
It is a mixed bag. 2wd are a bit lighter, easier to get in and out of. 4wd has a little more strength with the added pillar and easier to get gear out of the back. 4wd is nice for Parker while Lucerne 2wd is most popular. Really the one you already have or can get cheap is a good start.
You can ride all the rides and see all the sights here: http://www.jeepspeed.net/smf/index.php
