White xj people problems
DocMoe
So I get off work, and my Jeep won't crank.:bawl:
I have power and no check engine light, but it doesn't even try to start. In reverse the lights come on. I was still thinking it was the NSS. I pulled the NSS and opened it up and it seemed the spring were a bit gummed up with the yellow goo, but the contacts seemed pretty clean. I cleaned it with crc electronics cleaner and put a bit of Dielectric grease in there, and reinstalled the assembly. still no joy.
Any ideas? Thanks
blondejoncherokee
put it in N to start it. If that doesn't work, make sure the battery is fully charged. Mymoney is on the battery being dead. all the lights will work with a mostly dead battery. How is the fluid level inside the battery
scottmcneal
The 97 Club
You could try hitting the starter with a hammer if all else fails. I just had to hit the starter on my wife's jeep to get it to start. Time to clean it or replace it on hers
DocMoe
I tried N, no good. I figured the battery was fine because the gauge seems strong and all accessories seem strong usually on a dead battery there is a noticeable loss of power. But I'll check it out when I go to work tomorrow anyway. Jeep's still in the parking lot. my money is on a drained/dead battery
DocMoe
If it was the starter shouldn't I at least hear it try to start? When I turn the key NOTHING happens under the hood. But I'll try that too. At least I get to hit something with a hammer .
blondejoncherokee
put it on a legit charger and then test it will a real amperage tester. Otherwise, its NSS, or CPS, ignition switch . Verify that the starter solenoid is not fubar. or rats ate some wires somewhere.
Jeep450r
Don't just hit the starter, hit the solonoid on the side of it.
Jeep450r
A bad cps will still allow it to crank. Just won't get fuel or spark.
Phil
No check engine light at all ever when you turn the key to run?
We diagnosed my 94 4.0L as a bad computer because the check engine light was not coming on at all.
Swapped in a spare and it fired right up.
DocMoe
check engine light comes on normally when I first turn the key, then turns off as it should.
Thats what I was thinking as well from what I've read
smokinu
Im not sure of the year yours is. But isnt their a fusable link in the system? Maybe a faulty relay.
I had a bad relay when i first bought my jeep it would cold start fine. But if it was warm and you tried to restart it wouldnt.
