wipper speed 94 Cherokee
4x4fever
The wippers on high leave something to be desired. Is there anouther motor that will bolt in and speed them up
Matthew Currie
NAXJA Member #760
If the power circuit checks out, it might be worthwhile to open up the motor and check for dry bearings, especially in the output shaft. This can slow it down a good deal, and if your high speed is getting more like the low this could be the cause. I had this on my 87, and it was quite lively after a good relubing.
