WTB: Assorted stuff, Header panel, accessory drive, 97+
97XJ2
So in November I hit that deer. Finally getting around to getting parts together. Below is all the stuff I need to put it back together, I know some won't be available second hand. It is my fully inclusive list though. I am eliminating the mechanical fan and air conditioning.
Engine / Accessory Drive:
Water Pump (I'd like to replace as long as I'm in it to replace the pulley)
Tensioner / Power Steering pump and bracket
PS pulley
Mechanical Fan pulley / A/c bracket (for non-a/c vehicles)
Cooling:
Transmission cooler, plate style ~8x10" model is what I had
Body:
Complete header panel to include: headlight bezels and buckets, wiring harness. I have blinker pods and a grille.
Any help or parts is appreciated!
I have a JCR bumper, and a 3 row radiator already. I intend to go with the Gen Right PS pulley and the Dirtbound Offroad fan set-up. So for the time being I will also be researching how the serpentine system will be run now.
97XJ2
Missing a clip is fine, operational and in one piece is what counts here. A few of my plugs were broken and a more than a couple of wires pinched and split. Price?
hubs97xj
$20 shipped? Dunno what it's worth to anyone. I bought a complete "good" header panel that was actually trash, except for the wiring and a couple of signal lights. I'll throw the lights in for that too, if you need any.
97XJ2
That'd be great Kim, hold those lift parts as well :D
Also, define "cracked" on your header panel.
Hubs, that sounds reasonable as long as it has the outdoor temperature sensor. Any other lighting parts/bits you might have?
hubs97xj
The wiring for the OHC temp sensor isn't part of the lighting harness. IIRC, it's part of a harness that runs through the passenger side of the front end. I did just find the "missing" tabs for the lighting harness though, and I'll throw in a bit of wire loom for the bare section. It looked rough when I got it, so I stripped that section down to see if the wiring was damaged.
Stock lighting stuff
http://i266.photobucket.com/albums/ii244/AHhub/Jeep stuff for sale/DSCF5392.jpg
Also have a pair of H4 bulbs, 60/55, believe they're Autopals. That's about all of it that I won't be using.
XJosh95
Brian, not trying to jack your thread here, but....
Hubs, if Brian doesn't buy those Autopals, let me know what you're looking for them.
hubs97xj
Thinking $35 shipped for all of it, give or take a couple bucks. Found a sack of signal and marker bulbs, I'd throw those in the box too.
