wtb dana 30 & 3.5 or 4.5 lift spring for my xj
FuzzyD
i got a set of 4.5 lift rear leafs for my friend crashsomers and now all i need is a set of front springs for my xj, 3.5 or 4.5, also needed a dana 30 with the vaccum axle lock, if anyone has eather of them for super cheap let me know
Brandoson
what gear ratio do you need for the D30?
I have one with vacuum disconnect, and one without, different ratios.
Just curious, why do you need the vacuum disconnect? The one without can use the larger ujoints.
FuzzyD
disconnect is whats on right now, stock gears, dont know exactly, would rather replace it than rebulid it for now till i can afford to upgrade
stewie
andrew, we can tell you the stock gear ratio if we have some more information. if you have the 4.0L and an auto trans your ratio is 3.55. if its the 4.0 and manual gears, 3.07s.
CrashSomers
Dont listen to Stewie he dont know anything about jeeps.
By the way Stewie might need you this weekend to help me work on my jeep.:doh:
stewie
i feel the love here:smootch:. and i do too know something about jeeps- the improper use of the skinny pedal makes parts go boom, crunch or snap. but thats about it 'cause much more would over work my single brain cell...:lecture:
KRAKER
Stewie is prolly the best guy to have by your side in this chapter while you're scavengin the local JY's. He knows by heart all those stoopid mundane detalis about XJ's you wish you knew while you're out there.
Mdub
Andrew, I have a vacuum disconnect D30 with 3.55 gears. It only has 80k miles on it. Includes all steering for $99. You hit me up on AZVJC, I hadn't heard back.
