WTB NP231 Transfer Case
itscheesey
Chapter BOD
Need one ASAP. Mine blew today on the 15.
Sent from my XT1650 using Tapatalk
Anak
Stranger
Well that is a bummer.
So much for making it to AAT.
Not rebuildable? What is left and what would be needed to put it all back together?
BTW, you might want to specify year and transmission. Input splines and depths varied over the years.
itscheesey
Chapter BOD
It's for a 2001 with an automatic transmission. The case is cracked I haven't yet pulled it out. I'm working on it as soon as I have it out I'll post pics
Anak
Stranger
If I am reading the chart correctly that means you need a 23 spline, medium length input. That would come from a post 1990 AW4 or a '93-'95 46RH ZJ.
Busted up case is a bummer. That probably means you are best off sourcing a full replacement. Cases seem expensive. Although if it is the front half of the case you might see if someone has their old one after having done a TeraLow conversion or something like that.
itscheesey
Chapter BOD
Here you go G. It's cracked on both halves of the case. I'll post more pics in the morning after I pull it out.
Anak
Stranger
Ouch.
There probably isn't anything worth rebuilding there.
I would be curious what happened inside to cause that though. That is a pretty remarkable failure.
There are a bunch of transfer cases on the east coast on ebay. No one seems to know what a medium length input is though. This one says "short", but given the application it came from I expect it is actually "medium": https://www.ebay.com/itm/95-96-97-02-Jeep-Wrangler-TJ-XJ-Cherokee-Transfer-Case-4-0L-NP231J-23-Spline-231/152751267825?hash=item2390af5ff1:g:i1YAAOSwaopZi9FA&vxp=mtr
I don't know what a local JY is going to have. P&P is a roll of the dice. You might try that Jeep junkyard in Rialto, and there is another Jeep Junkyard down here in San Diego.
itscheesey
Chapter BOD
So the culprit has been determined as the ball and socket inside the double cardigan. It's mangled, I think when it finally gave way it bound up and caused enough Force to crack the case. The picture kinda sucks. I'll get a better one when I separate it
Anak
Stranger
I can't tell anything from that picture...
But I will be curious to see the better one once you have it.
I don't think even driveshaft shops bother to pay any attention to the centering ball. I have now redone two driveshafts, serviced/built by two different shops, where it was clear that neither shop bothered to do anything to ensure a long service life on those centering balls. I think the driveshaft shops look at it as a matter of job security.
Here are the details on the first one I went through: http://www.naxja.org/forum/showthread.php?t=1138113
itscheesey
Chapter BOD
Thanks to socalbill I got a T-case now. Finally got time to tear mine apart and as I unbolted it fell in pieces. Internals are all good though.
